Dear TestStand gurus,
I am trying to complete a custom text based report.
So far, I have been able to override the header without any problems.
My problem is in the following:
In a the current sequence, i would like to create one report entry per loop iteration result.
In fact, I have three nested loops. that generates a result. The report would display the name of the current sequence,
the parameters (extracted from the loop index) and the results.
So far, I have tried the following without success.
Create a new kind of step that will trigger to add some token to be added when the test is done.
This works good since after each test is performed I have an entry with tokens for each iterations.
My logic was to implement the callback for ModifyReportEntry and update its content with the values after each iteration.
Unfortunately, this does not work since the callback is only called once the sequence is completed.
So, Any ideas or suggestion on how to achieve this??Note: My next try will be to have a step at the end of the loop that will append a correct entry in a temporary file.
The callback to ModifyReportEntry would replace the token in the report with an entry from the temp file.
This should work but it looks like a lot of work for maybe nothing,
Note: Other possibility is to implement the sequence to generate the report as is.
And add a special action that creates another report.
EG
