05-22-2006 02:30 PM
05-23-2006 10:03 AM
05-23-2006 12:41 PM
05-24-2006 10:25 AM
Hi ab0123,
Do you see this error in the Sequence Editor as well?
You may also want to mass compile the whole TestStand directory as well as there are VIs that are also called.
Let me know what happens!
Hope this helps!
05-24-2006 12:32 PM
Have you tried it with the default simple OI which has been rebuilt using labVIEW 8.0.1, rather than your modified version?
Regards
Ray Farmer
05-24-2006 12:50 PM
I have rebuilt the simple Labview OI using LV8 and also mass compiled a copy of the demo Computer Motherboard Test seq VI's.
I have set the labVIEW adapter to use the runtime engine.
I have run the sequence file in the OI quite a few times now using the Test UUT's, But I am not seeing your problems.
What environment are you operating your system in?
Regards
Ray Farmer
05-30-2006 06:44 AM
