I have a CVI 7.1 project (.prj). I also have a TestStand 3.1 sequence that calls numerous functions within the various CVI source files. Without TestStand, I cannot run my CVI project (I think). But when I load my seq in TestStand and select Test UUT, I get an error that says
Error loading Step Pass/Fail Test ...
Unable to get Standard CVI Step Module address for DepotInitialize.
DepotInitialize is the routine I'm trying to call in the Setup tab of TestStand's sequence editor.
What I'm wondering is, how can I debug to see where the problem is occurring? Within CVI, I can either create a Release or Debug executable, but if my project consists only of files that perform specific tests, and therefore (the .prj) contains no main, how do I step into the code and test it.
What I've been trying to do is deploy using TS. I created a TS workspace that contains two TS .tpj files. The first points to my app .prj, .lib, .seq. The second points to TestStand's .exe, .ico, .uir files. I'm not sure if this is correct.
I'm confused on the relationship between TS and CVI .prj files. If I open my seq in TS, how does it know if I've built the CVI project as debug or release.
I just want to be able to step through my code. How do I do that.
