NI Home
Cart Cart | Help
You are here:
Reply
Member
mef526
Accepted Solution
TestStand: Create Sequence Group
Can I create a sequence group in TestStand sequence similar to the "Setup", Main", and "Cleanup" goups?
I'd like to have a sub group in these top level groups and use them like "#region" is used in C#.
Active Participant
~jiggawax~
Re: TestStand: Create Sequence Group
This is not possibe.  You can only have 3 step groups and they are defined for you.
What is your reason for doing this?  Maybe there is a better way to accomplish your goal.
jigg
CTA, CLD
~Will work for kudos and/or BBQ~
Member
don2000
Grouping actions and sequences would be greatly appreciated! I have quite some big sequences and subsequences, with groups I could easily step to the correct code part:
Now it is like this
  • LIN READ
  • LIN WRITE
  • LIN READ
  • LIN WRITE
  • LIN READ
  • LIN WRITE
  • LIN READ
  • LIN WRITE
but I would prefer this:
  • configuration
    • LIN READ
    • LIN WRITE
  • calibration
    • LIN READ
    • LIN WRITE
It is just a matter of readability. I would love this feature... (By the way, I am using TestStand 4.2.1)
Active Participant
~jiggawax~
Use the Label step to create separatioin.  You can Hide the Icon, Status and Name.  See Attached Picture:
jigg
CTA, CLD
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
