NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
sfla
TestStand 4.1 with Windows 7
When I launch TestStand with administrator rights, I have the following error :
Unable to access the TestStand configuration directory...
The solution is :
change the directory specified in the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\TestStand\<version>\CfgLocation
The problem is that there is no TestStand Directory on HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\
Does TestStand 4.1 run with Windows 7 ?
Trusted Enthusiast
Norbert_B
Re: TestStand 4.1 with Windows 7
[ Edited ]
TestStand Lifecycle Support.
TestStand 4.2.1 is the first version running on Win7 as a supported version. Previous versions *might* run on Win7, but are not supported.
Norbert
Active Participant
dug9000
If you are using a 64 bit os and regedit.exe you need to look under the wow64 node for the 32 bit version of the registry.
Active Participant
dug9000
More specifically, you should be looking under:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\National Instruments\TestStand
if using regedit.exe on a 64-bit OS.
-Doug
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
