07-30-2014 08:10 AM
Hey Keith,
I am the one who sent you the message with information on getting the crash dumps to us. I just re-sent the message. Usually, the forum will send you an email with a link to the message, but if not, you should be able to click on your profile on the upper-left of your screen and see your private messages on there.
Let me know if you still have trouble reading the message, and we'll figure out another approach.
07-30-2014 12:58 PM
Also, please send both dump files.
-Doug
07-31-2014 02:56 AM
Hi Doug,
I've just uploaded the earlier dump file; hopefully they will give you some clues.
Best Regards
Keith
07-31-2014 09:52 AM - edited 07-31-2014 09:55 AM
07-31-2014 10:07 AM
Hi Doug,
Your reply appears to be empty.
Best Regards
Keith
07-31-2014 01:53 PM
Ok, I was able to determine the cause from the first dump. The access violation is occurring because the PATH environment variable no longer exists which is causing TestStand to unexpectedly get a NULL pointer when calling the C runtime function getenv("PATH").
It is extremely unusual for the PATH environment variable to not exist. Is your code or code you are calling removing the PATH environment variable? Is this on purpose? If so, can you set it to something harmless rather than removing it?
Hope this helps,
-Doug
08-01-2014 04:18 AM
Hi Doug,
What a star player! - brilliant; it fixed it even without a re-boot.
I am eternally grateful for all the help you guys have given.
Have a great weekend and if we should ever meet I'll buy a round of frothy lemonades.
Best Regards
Keith
08-01-2014 10:17 AM
Glad I could help. We will likely fix this in a future version so that it will work even if there is no PATH environment variable. Thanks for bringing the issue to our attention.
-Doug
