10-30-2015 05:11 AM - edited 10-30-2015 05:14 AM
I am trying to run TestStand 1 on-line course exercise 8-3 solution (unmodified) and it just hangs on the first step after the Lock step - a message popup.. If I run the same sequence using sequential or parallel models, it runs just fine.
TestStand itself does not hang, only execution of the sequence. No errors. Can this be caused by wrong station settings?
Please advise.
Does not work on: NI TestStand 2014 SP1 (14.0.1.103) 32-bit
Works on: TestStand 2014 SP1 (14.0.1.103) 64-bit
11-02-2015 08:47 AM
So you are unable to get it to run in batch model? Can you try to run the sequence with another 32-bit software, if you have one, and verify that the 32-bit has the same settings as the 64-bit..
