Hi SajK,
Are you referring to the LEDs in the List Bar on the left hand side of the OI that is associated with a particular sequence?
If so, the functionality you want to modify is controlled by the
ExecutionViewMgr, and is read only. In order to change the way in which
those icons are determined / displayed, you would need to disconnect
the ExecutionViewMgr from the Listbar. However in doing this, you'd
also be losing the automated functionality such as the display
messages, displaying multiple executions at the same time, etc. In
essence, you would have to re-invent a lot of features that the
ExecutionViewMgr takes care of for that List bar.
An easier, although slightly more work-around-ish option, is to simply
change the icon files that TestStand is using for the various states.
All of these icon files can be found here:
C:\Program Files\National Instruments\TestStand 3.x\Components\NI\Icons\NI_UIControls
You could simply change, for example, "ExecFailed.ico" to a solid red led, and TestStand would grab that on execution.
That would be the easiest way.
Hope this helps SajK, have a good one.
Dan Weiland
Applications Engineer
www.ni.com/support
Dan Weiland
