NI TestStand
Test stand start up very slow
On one of my computer (win7 64bit pro), Test stand 2014(32bit) now start up very slow, maybe 1 or two minutes.
and during normal work, very often the GUI not response for around 1 minutes then goes back.
I tried uninstall test stand and re install back but no use (I did not uninstall all NI stuff)
what's the problem? I have to uninstall all NI things?
Nemo
(3,287 Views)
NemoChen, I'm curious what your search directories are set to. Usually that is the main culprit of slowness. Can you send a screenshot? Or better yet, your TestExec.ini file? Regards,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,270 Views)
thank you!
I just re installed all NI things. Now looks it works normal.
if something happen again, I'll update this post again.
Thank you!
(3,262 Views)
