I run batch model and skip socket 1 during the run. Teststand 2014 does skip the socket but when the batch is completed. The display does not the test socket as disable but has a green check mark as the picture show
Teststand 2010 working does show the socket was disable while teststand 2014 does not.
To clarify, when running a Batch Model in TestStand 2014 the socket is not skipped during execution, but it is on TestStand 2010. Is this correct? How are you disabling the test socket 1?
Briana P. Licensing Sr SW Engineering Manager | NI R&D ni.com/support
