05-22-2015 03:49 AM
Using TestStand 12 sp1, batch model.
Is there a simple way yet of having the Test Socket index to start at 1 in the GUI (rather than the inexplicable 0), along with the Test Socket index in the report?
05-22-2015 07:32 AM
05-22-2015 10:13 AM
I am a programmer but when you connect hardware to your test system you always start from 1 (as 0 does not exist).
I have an old version of cvi (ver 6 I think); is it possible to use this; if so how?
05-22-2015 01:01 PM
05-22-2015 02:35 PM
modelsupport2 is unrelated to the UI. You do not need CVI for the UI. The UI is written in 5 different languages, all of which you have the source code for with TestStand: LabVIEW, CVI, C#, VB.NET, C++.
However, modelsupport2 is related to the reporting and you will need CVI to change it if you need to. Look at NI_ReportGenerator.seq plugin to see how the reports are being generated. Or you can just create your own reporting plugin in your own language.
05-22-2015 02:35 PM
I may have misunderstood... which GUI are you talking about?
05-22-2015 06:40 PM
05-26-2015 02:55 AM
I guess without a newer version of Cvi then it cannot be done.
I don't suppose anyone out there has got a modified batch gui (modelsupport2) that indexes from slot 1 rather than slot 0?
05-26-2015 08:31 AM
