I have implemented an Application Manager callback for the
DisplayReport event. In my callback, I am only launching the report
viewer for reports that failed (TS_ReportLaunchViewer). The name of the
report is built using the sequence name as a prefix to "report". The
serial number is also used as part of the name:
cbb_report[SerialNumber].xml
I am getting the callbacks ok and appear to be displaying only the
reports that failed as intended. I do have a couple of small quirks
that concern me however. Let's assume that I have two reports that I am
expecting from failed sockets, cbb_report[456].xml and
cbb_report[789].xml. In the callback, I retrieve the location of the
report and it seems correct, i.e. path\cbb_report[xxx].xml. It is
correct for both instances of the report. The quirks are:
1. Even though the location property indicates that the report is
path\cbb_report[456].xml, the viewer is showing the loaded report at
path\TempReport_00006.xml. The contents of the report are correct.
2. The second file caused two reports to be displayed even though the
callback was entered once for it. Both reports are the same and are
correct but I was only expecting one. The two reports had different
names: path\TempReport_00007.xml and \path\cbb_report[789].xml.
Can anyone explain this behavior and what I can do about it?
John
