08-22-2013 08:16 PM
I noticed the file TSSuppRef.chm file is missing from NI TestStand 2013. However, the file exists in NI TestStand 2012. The default location is
C:\Program Files\National Instruments\TestStand 2013\Doc\Help\TSSuppRef.chm (32 Bit Windows 7).
To make a temporay fix I just copied the TSSuppRef.chm file from from TestStand 2012 to from TestStand 2013.
08-23-2013 12:20 PM
Hi Pete,
Were you encountering an error or a problem that was fixed by that workaround? If so please describe it for us so we can document it and include it in the next patch if it is a bug.
08-23-2013 12:38 PM
My temporary work around solution would apply if someone had TestStand 2012 and Teststand 2013 installed on their same machine. If TestStand 2012 is not installed on the same machine this work around solution would not work.
I simply copied C:\Program Files\National Instruments\TestStand 2012\Doc\Help\TSSuppRef.chm
to
C:\Program Files\National Instruments\TestStand 2013\Doc\Help\TSSuppRef.chm.
At least now I am able to look up help on TSSuppRef documenation for TestStand 2013.
08-27-2013 08:19 AM
Hi Pete,
I looked into it and found that the file in question has been renamed TSSyncServer.chm in the help files, so no need to make an additional copy of it.
08-27-2013 09:35 AM
Basil is correct. The TSSuppRef.chm file was renamed TSSyncServer.chm and now includes only the API information. All other information that appeared in the TSSuppRef.chm file has been integrated into other .chm files within the NI TestStand Help. No information was removed from the help system. There is no need to copy TSSuppRef.chm from previous versions of TestStand into the TestStand 2013 Doc\Help directory.
Please let me know if you have any other questions or need more information.
Callie Jones
TestStand Documentation Team
08-27-2013 11:39 AM
So how do I tell or set TestStand 2013 to look for that new file name and path?
08-27-2013 12:03 PM
Where is it looking for the old file name? You shouldn't have to tell it anything.
-Doug
08-27-2013 12:16 PM
As I said earlier my version of TestStand 2013 looks for the path of TSSuppRef.chm in
and it is not there.
Here is the error message I am getting:
(See Attachment)
08-28-2013 09:57 AM
What do you mean TestStand's looking for it? Do you mean you launch TestStand and immediately get an error? What do you have to do in order for the error to occur? When does the error occur?
08-28-2013 10:09 AM - edited 08-28-2013 10:26 AM
Someone pointed out to me that the reason you are getting the error is that you are using the .fp file from TestStand 2012 rather than teststand 2013. But in looking at this more carefully it appears that even the 2013 .fp files are pointing to the wrong help files. Thanks for pointing this out. We will fix this in a future version. In the meantime, either using the older help file, or manually going to the function in the newer help file is probably the best workaround.
-Doug
