NI TestStand
TS2014 file saved as TS2013 one meets error -17098
Hello:
    I've remove selection on station options-->localization-->recognize multi...., and save seq file as TS2013(5.1x) format. but still meets error code-17098 as below:
Images intégrées 1
version of TS2013:
Images intégrées 2
(4,243 Views)
Accepted by topic author muxingjun
That file is not being saved as 2013. How exactly are you trying to do this? To save as 2013, use the "Save As" dialog box and set the filter to 2013 and then choose a location. Make sure you are using the file saved to that new location. You can look at the header for the file to see the version info using notepad.exe (even for binary format, you will see the version numbers at the top of the file).
Hope this helps,
-Doug
(4,227 Views)
OK, got it. that's because of I save as the file in same location and replace the original file. thanks!
(4,200 Views)
