NI TestStand
TS sequence editor and deployment licence
Is there any chance to use sequence editor with Deployment not Development licence?
Tahnks
Message 1 of 8
(4,556 Views)
NI here says:  "Debugging steps and sequences involve making minor changes to these components to fix issues in the application. Making changes to steps and sequences that add or improve functionality is considered development and requires a development license."
The TestStand Debug Deployment Environment is what you are looking for.
Message 2 of 8
(4,549 Views)
Yes but how to switch it on?
Will it be enough just to login to the TSOI as the operator?
Message 3 of 8
(4,538 Views)
Once you have activated the TestStand Debug Deployment License, you can open SeqEdit - which you must have installed Smiley Wink
Message 4 of 8
(4,532 Views)
I use VLM.
On VLM there are two types of licences: Development and Engine deployment.
I'd like the sequence editor to use Engine deployment licence. Can I do this?
Message 5 of 8
(4,530 Views)
I guess that you Engine Deplotment is the Base Deployment.  (Maybe someone knows better?)  If it is, the license will not allow the usage of SeqEdit, see here.
Message 6 of 8
(4,527 Views)
Hi MimiKLM,
I'd recommend giving NI a call ( www.ni.com/contact ) and talking through what license you have available at your place of work with our licensing and sales team.
Best Regards,
Message 7 of 8
(4,522 Views)
Good proposal. Just wondering why it didn't come to my mind?
Message 8 of 8
(4,517 Views)
