03-22-2006 11:50 AM
04-06-2006 02:37 AM
Have to got the label Error: in your function code.
If you have use TestStand to create your c file, then towards the end of the function you will probably find some commented out code for handling the error condition.
You will need to make sure the line with Error: has been uncommented
Hope this helps
regards
Ray Farmer
