Hi Rafi,
Are you referring to LabVIEW’s table datatype? If so, then to perform a mathematical operation on the columns or rows of the table, you will actually need to extract out that particular row or column array and then perform the desired mathematical operation. In some cases, there is a more efficient operator that is available to operate on an array of values rather than a single value (refer to the Numeric palette for details).
However, do note that the table refers to its elements as strings. Therefore, before any numerical operation can be performed, you will need to first do a string to number conversion (look in the String/Number Conversion palette under String).
Hope this helps!
Kileen
