NI TestStand
TEST OK apres 3 failed
please i need you help
I have a table of values I have to compare each value to a limit template failed with a number 3 : if the number exceeds 3 thus failed the test will KO
thank you
(3,591 Views)
I'm not sure if I understand your question. It sounds like you are running a TestStand sequence and want the functionality of a numeric limit test. This link has some more information on that
http://digital.ni.com/public.nsf/allkb/F9F5D474B7AFD46E86256E890078AD31
If you are new to TestStand, you also may want to consider taking some training courses before you dive into development.
http://sine.ni.com/tacs/app/fp/p/ap/ov/lang/en/pg/1/sn/n8:33/
https://www.linkedin.com/in/trentweaver
(3,558 Views)
