NI TestStand
System Level Exception -1702 with TestStand2.0
Hi everyone,
I usually use Labwindows/CVI and TestStand product.
On a new PC I have just installed Measurement Studio 6.0 and after TestStand 2.0
To check if all install are OK, I tried to run the example ..\examples\demo\c\auto.seq and the error System Level Exception Error Code : -1702 appears randomly, It's exactly the same with my sequence application
I don't understand why ? Could Help me
PC configuration :
Windows XP Pro version 2002, service pack 1
Penium(R) 4 CPU 2.8 GHz
RAM 512 Mo
Software installed
Measurement Studio 6.0 with LabWindows/CVI
TestStand 2.0
Thanks a lot in advance.
Glou.
(3,243 Views)
this link may help
Is your teststand version 2.0 or 2.01f1?
Regards
Ray Farmer
Regards
Ray Farmer
(3,239 Views)
Thanks for you fast answer but the problem still exist. I'm not use Visual C++ (it's not installed on PC) and for TestStand is TSengine 2.01f1 and Sequence Editor 2.0. I have tried with and without report ascii/html generation ans it's the same
(3,238 Views)
Could you tell me if you obtain the same error by using an Operator Interface instead of the Sequence Editor. Do you have the same issue by logging as a different user (for the windows session)? If that is the case please let me know. Otherwise, I suggest you to reinstall TestStand.
(3,208 Views)
