11-16-2005 07:45 AM
11-16-2005 08:19 AM
I am not very sure whether you want to skip a LV vi call or you want to stop the LV vi execution at some point of time after it starts executing
If it is case1:
Then you can have precondition for any step (not only for LV vi calls)- and execute the step only when the precondition passes
If it is case2:
You can pass the TS sequence context to the LV vi call and get any needed parameter value which decides the vi to continue or stop.
I have attached a sample Lv vi for your reference. I hope that it helps.
Sas
