11-30-2005 02:01 PM
11-30-2005 03:39 PM
12-01-2005 01:40 AM
the behaviour is expected. But it does not tell how to make the sequence stop on a fail but still give me a report file.
12-01-2005 02:10 AM
12-05-2005 02:05 AM
But I'm not quite happy with the behaviour from TestStand here.
If I set the options as follows
engine->StationOptions->AlwaysGotoCleanupOnFailure = FALSE;
seqContext->Main->Sequence->GotoCleanupOnFailure = TRUE;
seqContext->Sequence->GotoCleanupOnFailure = TRUE;
I do get a report when a sequence fails. However, the sequence will not immediately go to clean-up on a step failure (it will first complete the sequence call). How can I make sequence go to clean-up immediately at step failure and still give me a report file?
12-06-2005 01:25 AM
If I understand you correctly, In your sequence, if any one of the steps fail, you dont want any remaining steps executed.
You can do this but you would have to set the Failure Post Action of each of the steps to goto the cleanup. This is done in the Properties Dialogbox of the Step.
Regard
Ray Farmer
