10-31-2005 08:56 AM
10-31-2005 09:39 AM
10-31-2005 09:58 AM
That is what is used in the final step, which returns without error, but without modifying the value.
Anyone else have a clue?
Hurst C.
10-31-2005 03:15 PM
10-31-2005 03:33 PM
10-31-2005 03:49 PM
There are a number of Get.../Set... functions in this file (I have not shown all) and they all share sTEEngineObj. The first one requiring it initializes it. As for the path string "StationGlobals. ...", it needs to be that way because it comes out of a .h file and is used elsewhere. I advanced the pointer to beyond the "StationGlobals." because of the sharing. I abhor multiple definitions for essentially the same thing.
Hurst C.
10-31-2005 04:19 PM
11-01-2005 01:09 AM
I assume, when you say "my application" that you are running some sort of operator interface as well as the SeqEditor.
Unfortunately, when you launch two TestStand Applications they both share the StationGlobals file as well as other resourses.
I'm surprised you didn't get some sort of warning that the StationGlobals file had changed, when you switched between one application and the other. Anyway you would have had to refresh it by loading the file again, (I think there's a method you can call to do this), before you can see the change.
Regards
Ray Farmer
11-01-2005 07:35 AM
11-02-2005 03:44 PM
