08-11-2016 05:42 AM
Does anybody know if it is possible to break an executing sequence and then single step over individual steps of a sequence using the TestStand API?
Break and Resume execution are no problem but single stepping once execution is broken is proving illusive.
Any thoughts greatly received
Steve
Solved! Go to Solution.
08-11-2016 05:46 AM
The execution object discloses methods for this.
Norbert
08-11-2016 07:30 AM
Hi Norbert, thank you for your reply. The execution object was my first thought, can you be more specific?
08-11-2016 07:41 AM - edited 08-11-2016 07:42 AM
Apologies, found the method in the execution object. Couldn't see the wood for the trees.
Thanks Norbert
