NI TestStand
Single Stepping through a TestStand Sequence using the API
Does anybody know if it is possible to break an executing sequence and then single step over individual steps of a sequence using the TestStand API?
Break and Resume execution are no problem but single stepping once execution is broken is proving illusive.
Any thoughts greatly received
Steve
(3,349 Views)
Accepted by topic author SercoSteveB
The execution object discloses methods for this.
Norbert
Norbert
Expert: Geometry
(3,346 Views)
Hi Norbert, thank you for your reply.  The execution object was my first thought, can you be more specific?
(3,329 Views)
Apologies, found the method in the execution object.  Couldn't see the wood for the trees.
Thanks Norbert
(3,325 Views)
