I am using TestStand 3.1 engine in combination with Labview 7.1. Everything works fine until I run a sequence file. After this run the logout/login and the shutdown do not work anymore. The complete engine hangs. When I look at the description of the shutdown method it says;
<QUOTE> Closes opened sequence files and executions. This method also releases the TestStand Engine. <UNQUOTE>
