12-18-2006 04:59 AM
12-18-2006 05:29 AM
The apply change will only happen if the affect sequence files are already loaded.
What you need to do is change the version of the step type, so that when a sequence file is loaded, you will get a conflict displayed that there is a difference with the step type in that sequence file, this will give you some options as to which step type to use.
Hope this helps
Regards
Ray Farmer
12-18-2006 06:04 AM
12-18-2006 06:13 AM
