NI TestStand
Show additional results only if fail
Is it possible to display additional results in a report only if a test fail?
(4,198 Views)
Additional results have a "Condition" field. As it is an expression, you can enter the filter for failing of the UUT.
Norbert
Norbert
Expert: Geometry
(4,186 Views)
Thanks, but what expression? 🙂 I couldn't find a right one.
(4,167 Views)
Depending on where the step is located vs. where the FAIL step is located (sequence-wise), you could use something like "RunState.SequenceFailed==true" as filter.
Norbert
Norbert
Expert: Geometry
(4,159 Views)
