Hi Tennessee,
If you are going to launch a step which is going to run for 5 hours and not return back into TestStand until it is finish, then why are you going to use TestStand at all?
What is TestStand going to give you that you cannot do in LabVIEW or CVI?
TestStand going to give you a lot of over head, do you actually need this for the task in hand?
The reason you use sub-sequences, is pretty much the same reason you create sub-vi's or procedures in C
The reason you use Teststand, is to make use of the sequencing of a series of tests, logging of results, evaluation of results, generation of reports, user management.
Regards
Ray Farmer
Regards
Ray Farmer
