06-24-2013 06:28 PM
Hi
With TS2012 SP1 in the Configure>Result processing dialog I have created a report configuration I would like to use with a sequance. Is there a way to set the report configuration option in the sequence?
I can see there is a ReportOptions callback - however its just a lot of properties (I think from the report dialog).
Since I have congfured what I want in the report dialog - is there a simple way to set the active report configuration on sequence load?
I ran a test last night and forgot to swap to my custom report conifguration from the default xml setup. 😞
At least this page http://digital.ni.com/public.nsf/allkb/D58F2C45415179C786257AA9004E52D0 helped me get the results into excel (after hacking the registry!).
Cheers
Nick
06-25-2013 02:22 AM
Nick,
the callback "ReportOptions" is indeed the correct location to set default values for reporting in a single sequence file.
Of course, you can place the same functionality in a sequence load callback, but you don't have the variables as parameter at hand there. So it is a little more effort to write the configuration into the correct place.
And you have to write the settings individually.
A complete different way would be to directly meddle with the config files from TestStand. You can refer to this post for a general entry point.
hope this helps,
Norbert
06-25-2013 11:24 AM - edited 06-25-2013 11:25 AM
Here is another approach (TS 2012 and beyond only):
a) In Configure>>Result Processing, set the configuration to contain a single result processor that has the report settings you want.
b) In a new sequence file, right click on the sequence list and select Sequence File Callbacks... Add a ModelPluginConfiguration callback.
c) Set a breakpoint in your new ModelPluginConfiguration callback and then run the sequence file with Single Pass.
d) At the breakpoint, select Parameters.ModelPluginConfiguration.Plugins[0] from the variables view and choose Copy.
e) Terminate execution, select Locals in the ModelPluginConfiguration and paste. Rename the new Local variable as MyReportConfiguration.
f) Expand Locals.MyReportConfiguration.Base.RuntimeVariables.InitializationState and set it to 0.
g) Add a statement step to the callback with the following expression:
SetNumElements(Parameters.ModelPluginConfiguration.Plugins, 0), // clear existing configuration, if any. Delete this line to append your report to the existing configuration
Parameters.ModelPluginConfiguration.Plugins.SetPropertyObjectByOffset(GetNumElements(Parameters.ModelPluginConfiguration.Plugins), PropOption_InsertElement, Locals.MyReportConfiguration.Clone("", PropOption_DoNotShareProperties | PropOption_CopyAllFlags)) // append my configuration
h) copy the ModelPluginConfiguration callback sequence to any file you want to use the report configuration you specified
06-26-2013 01:17 AM
Thanks Guys.
I like James' solution however it is a bit of a work around. I might create a suggestion on the ideas forum.
At this stage I think the simple solution is a reminder dialog on SequenceLoad.
Cheers
Nick
