10-31-2005 08:05 AM
11-01-2005 06:31 AM
11-01-2005 02:32 PM
11-02-2005 05:34 AM
Perhaps you didn't understand me I am using in each thread different serial port
11-02-2005 02:33 PM
11-03-2005 10:12 AM
Hi
This is a small part of my code where I isolate the problem I double check this and it can run
in every computer that has two serial port at least.
in this code I do 3 operation 1- open com , 2 - send data , 3 - close com
when this code run in serial mode it is working fine and the parameter to success
is comparing the return value of the function 'ComWrt' with the count parameter (sbuffer)
it has to be equal in case the device is working good.
You can run this code in your computer and see the problem when running this sequence
in Batch model step parallel .
11-04-2005 10:30 AM
11-08-2005 08:34 AM
Hi
The code was attached in 'reply 2'.
I write all the information you need in 'reply 6' and explain the attached code.
11-08-2005 09:14 AM
Should your pre-expression "Step.Com = RunState.TestSockets.MyIndex + 1" be looking for the MyIndex value from one level down eg
"RunState.Caller.RunState.TestSockets.MyIndex".
Regards
Ray Farmer
11-08-2005 10:20 AM
