I have a four DUT load board and I need to run a set of tests serially, one DUT at a time. I tried creating a Serial Section in my test flow but the tests continue to run through all four DUTS one test at a time. Each test is configured for serial Batch Synchronization. Attached is a reduced version of my sequence. Never mind the test names. I made them generic.
I expected all 5 steps inside the serial section to execute for DUT0 before beginning to test DUT1. This didn't happen. What happened was Continuity executed serially for all four sites, one at a time; then PS Shorts executed serially for all four sites one at a time; etc. This is the same behavior as I had before added the serial section.
I assume that Batch Synchronization set to Serial mode is what the manual means by a "Serial Section". I could only find the one paragraph in the manual on this subject.
Bob
