09-08-2005 09:36 AM
09-08-2005 11:00 AM
Row colors are not currently configurable in the default sequence editor, although I would expect that to change in some future version of TestStand.
Currently, in an operator interface or custom editor that uses the SequenceView UI controls, you could set the Step Background Color expression for the SequenceView control as design time to:
TypeOf
(Step) == "NI_Lock" ? tsYellow : 0x80000005 /* syscolor for window bg */ This will color the background of Lock steps from just after the step icon to the end of the last column. It is possible that a future version of TestStand might extend the application of the background color across the entire row.
09-09-2005 02:29 PM
09-12-2005 01:17 AM
