05-05-2015 12:00 PM
I need to write a small CSV file with my sequence test results. The way I am considering doing this is to
Is this a reasonable way to do it? In which variable does the overall UUT pass/fail result get stored?
StephenB
05-05-2015 12:35 PM
I recommend against doing it this way. What you want to do defeats the entire purpose of using TestStand in the first place.
If you are using a newer version of TestStand (2012 or newer) I would create a custom plugin to do exactly what you are doing.
There is a ton of information out there on plugins.
Here is an example on probably what you are trying to do:
http://zone.ni.com/reference/en-XX/help/370052N-01/tsexamples/infotopics/modelplugin/
Here are some more links that are important:
http://zone.ni.com/reference/en-XX/help/370052K-01/tsfundamentals/infotopics/pmpcreatingplugins/
The advantage of using a plugin is that now all tests can utilize it as opposed to the report generation being specific to a single test.
Hope this helps,
