NI TestStand
Sequence pass/fail variable for csv report
I need to write a small CSV file with my sequence test results. The way I am considering doing this is to
  • save the information I need as the test progresses in local, file, or station global variables
  • make a report string using the values stored in these variables, and
  • write the string to a file via a LabVIEW VI.
Is this a reasonable way to do it? In which variable does the overall UUT pass/fail result get stored?
StephenB
(3,862 Views)
I recommend against doing it this way.  What you want to do defeats the entire purpose of using TestStand in the first place.
If you are using a newer version of TestStand (2012 or newer) I would create a custom plugin to do exactly what you are doing.
There is a ton of information out there on plugins.
Here is an example on probably what you are trying to do:
http://zone.ni.com/reference/en-XX/help/370052N-01/tsexamples/infotopics/modelplugin/
Here are some more links that are important:
http://zone.ni.com/reference/en-XX/help/370052K-01/tsfundamentals/infotopics/pmpcreatingplugins/
http://zone.ni.com/reference/en-XX/help/370052M-01/tsfundamentals/infotopics/process_model_plugin_ar...
The advantage of using a plugin is that now all tests can utilize it as opposed to the report generation being specific to a single test.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,858 Views)
