NI TestStand
Sequence pass fail or terminated
Hi there.
In my teststand sequence cleanup (see attached) I have an "if" "else" statement that will log a "TEST_PASS" or "TEST_FAIL" whether the test has passed or failed.
What I am finding is that if the test is terminated it logs as "TEST_PASS", but I would actually like it to log as "Terminated".
What would be the best method for doing this?
TIA
Jim.
LABOR OMNIA VINCIT
(6,011 Views)
You can use Execution.GetStates to get the termination state and the RunState.
Save this to a local variable and then use that in your IF statement as well.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,999 Views)
Hey there, sorry for delay in response.... so if I used "RunState.Exection", what expression do I require to capture terminated, guessing in my cleanup I require somthing along the lines;
If  RunState.Exection ??????
f(x) Statement FileGlobals.TestResult="TEST_TERMINATED"
Else if RunState.SequenceFailed==False
f(x) Statement FileGlobals.TestResult="TEST_PASS"
Else
f(x) Statement FileGlobals.TestResult="TEST_FAIL"
End
TIA!
LABOR OMNIA VINCIT
(5,849 Views)
Accepted by topic author jimbobaggies
Just in case anyone searches and is looking for similar, here is the solution I have reached with help of NI Support;
Create two local variables called runState and termState, my cleanup section is now as follows;
f(x) Statement RunState.Execution.GetStates ( Locals.runState, Locals.termState)
If  Locals.termState!=1
Else
End
LABOR OMNIA VINCIT
(5,810 Views)
