NI TestStand
Sequence file load and unload once Execution Ends
Dear All,
I am calling a sub sequence from my main sequence. I Set the property of sub sequence unload option to unload when step executes. When Execute My Main Sequence its not unloading the subsequence after execution. When I close the main sequence file then it unloads the sub sequence.
My Requirement is to unload the subsequence once it is finishes the execution.
In My subsequence file I have called “SequenceFileLoad” and “SequenceFileUnLoad” to load and unload the sequence I have put the msgbox to monitor the same.
Thanks & Regards,
Sathyendra N
(3,449 Views)
In the Sequence Properties of the MainSequence, Uncheck the 'Optimise Non-Reentrant Calls to This Sequence'
Regards
Ray Farmer
Regards
Ray Farmer
(3,446 Views)
Hi Sathyendra,
To rephrase Ray's response:
In the Sequence Properties of the MainSequence of the SubSequence, Uncheck the 'Optimise Non-Reentrant Calls to This Sequence'
Cheers,
David Goldberg
Cheers,
David Goldberg
(3,426 Views)
Hi
Thanks for your response David and Ray.
Its working.
sathyendra N
(3,407 Views)
