NI TestStand
Sequence File Converter Help
Example and command line usage is different in Sequence File Converter Help
The File <file or directory path> should not have a "-" in Example.
Thanks & Regards
Varaprasath M
Certified LabVIEW Architect
Certified TestStand Architect
(3,875 Views)
Noted and will be fixed, thanks.
Scott Richardson
(3,744 Views)
