NI TestStand
SeqEdit.m Error, can't use TestStand
I have recently installed TestStand 2012, then SP1.
As soon as I try to create a step in the sequence editor the following pop shows up. Help please.
"Error occurred while trying to refresh edit panel 'SeqEdit.m':
Could not load file or assembly 'stdole, Version=7.0.3300.0. Culture=neutral, PublicKey Token=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified. "
(3,631 Views)
Have you tried rebooting? Repairing the installation? Another machine? Did it happen before installing SP1 or only after?
-Doug
(3,613 Views)
Hi Doug,
I have rebooted but not tried to repair the installation. Same happened on another machine. I didn't really try teststand before installing SP1, just opened and closed it after seeing the log in pop-up box.
At that point I had no reason to believe something went wrong. I have a fair bit of experience installating NI software, never seen that before.
Kind Regards,
Christophe
(3,607 Views)
Accepted by topic author Christophe_LV
I have done a repair and TestStand now works. I didn't think that kind of things could happen on a fresh intall.
(3,602 Views)
There might be an issue with the installer. Please tell us in as much detail as possible exactly what you did to see this error.
-Doug
(3,592 Views)
