07-12-2005 09:38 AM
07-12-2005 01:54 PM
07-13-2005 12:54 PM
Hey Roons,
TestStand actually makes this really simple for you. After you have created your new schema within the Database Options dialog, return to the Schemas tab, and click on the Build .sql File. This will bring up a file save dialog box and will allow you to save the .SQL file that will build the tables necessary to utilize the schema. You will want to run this .SQL statement on a database that does not have tables currently that are named the same as the tables in your schema, otherwise you will get an error that the table already exists since it builds CREATE TABLE commands. Give this a shot and let me know if you have any additional questions. Have a good one.
07-13-2005 01:49 PM
07-14-2005 11:01 AM
10-13-2006 08:33 PM
10-16-2006 11:32 AM
10-16-2006 08:26 PM
10-16-2006 08:35 PM
