08-09-2005 03:23 PM
08-10-2005 12:28 PM
08-12-2005 08:03 AM
08-12-2005 10:00 AM
add /quit to your command line.
TestStand Reference Manual Chapter 8 >> Customizing and Configuring TestStand >> Configuring TestStand >> Sequence Editor and Operator Interface Startup Options document the available command line arguments.
04-03-2006 04:20 AM
I also have the same problem as described above, but after going through the answers, I could easily run my sequence using the "Command Line Arguments". But the problem is, it is not able to generate the report file... is any other command to run a sequence and generate the corresponding report?
Please Help.
Sreedhar.
04-04-2006 12:05 PM
04-04-2006 11:42 PM
Hi Dan,
What I am doing presently is: I made a Batch file, in which I wrote the command line arguments. Now, in the batch file, I am loading the SequentialModel.seq and in the MainSequenceCallback (subsequence in SequentialModel.seq), I am hardcoding its parameter for a particular sequence, so that whenever I run the .bat file, only that particular sequence is getting executed and accordingly a report is being generated. My .bat file looks like this:
"C:\Program Files\National Instruments\TestStand 3.1\Bin\SeqEdit.exe" "C:\Program Files\National Instruments\TestStand 3.1\Components\User\Models\TestStandModels\MySequentialModel1.seq" /runEntryPoint "Single Pass" "C:\Program Files\National Instruments\TestStand 3.1\Components\User\Models\TestStandModels\MySequentialModel1.seq" /quit".
I have named sequentialmodel as MySequentialModel1.seq, please find it attached.
I found only this way to generate report. Because, without running the SequentialModel, how can cater for generating a report.
Please tell me if there is any other way.
Thanks and Regards
Sreedhar.
04-05-2006 12:34 AM
You shouldn't be running the process model sequencefile like that.
In your command line, if you have a normal sequencefile instead of a process model, the fact that you had an entry point as well means the sequencefile will load and run the MainSequence using the process model entry point "Single Pass".
eg
"C:\Program Files\National Instruments\TestStand 3.1\Bin\SeqEdit.exe" "C:\Program Files\National Instruments\TestStand 3.1\Examples\MyExamples\MySequenceFile1.seq" /runEntryPoint "Single Pass" /quit.
Regards
Ray Farmer
04-05-2006 01:11 AM - edited 04-05-2006 01:11 AM
I have replaced my batch file with the following text: "C:\Program Files\National Instruments\TestStand 3.1\Bin\SeqEdit.exe" "C:\Seq2.seq" /runEntryPoint "Single Pass" /quit.
on doing this the teststand is throwing me an error saying : Command Line arguments missing.
What I did is, instead of this path i.e. "C:\Program Files\National Instruments\TestStand 3.1\Examples\MyExamples\MySequenceFile1.seq", I replaced with the path of my sequence file as I have shown above.
please correct me.
also I am attaching, the error message that was thrown...
Message Edited by TSreedhar on 04-05-2006 01:15 AM
04-05-2006 01:41 AM
