I'M A NEW USER OF TEST STAND (3.1) AND MY QUESTION IS, PROBABLY, VERY SIMPLE FOR YOU:
IN A STEP "ACTION" I NEED TO GENERATE, WITH LABVIEW 7.1, A SQUARE WAVE FROM THE AO0 OF MY PCI-6071E; AFTER STARTING GENERATION, I NEED TO VERIFY SOME NUMERIC LIMIT TEST AND, AFTER THAT, I NEED TO TERMINATE THE GENERATION.
THE VI I CALL IN THE "SPECIFY MODULE" USE A WHILE LOOP FOR CONTINUING GENERATION (DAQMX) SO, TO PROCEED WITH THE SEQUENCE, I HAVE TO STOP THE VI AND, THEREFORE, THE GENERATION.
I NEED SOMETHING SIMILAR A GPIB CALL, WHERE THE INSTRUMENT "LATCH" THE COMMAND I SEND IN THE STEP "ACTION" AND RETAIN THIS STATE UNTIL I WILL SEND ANOTHER GPIB COMMAND.
CAN YOU KINDLY HELP ME? I NEED URGENTLY A SOLUTION!
THANK YOU VERY MUCH IN ADVANCE
BEST REGARDS
STEFANO
