02-05-2016 11:13 AM
Hello!
I have a system that works great on the develepment system and the errors are trapped but when I make a deployment and move it to the deployed location the errors that are supposed to be handled in my error handler in the SequenceFilePostStepRuntimeError callback. In the deployment each error comes up as a runtime error popup and the system does not move forward to clear. It needs user interaction.
I'm sure it is a setting somewhere that I'm missing. Any suggestions?
Bill
02-08-2016 10:53 AM
Configure>>Station Options
On the Execution tab what does the On Run-Time Error have set?
Make it the same on your deployment machine as your development machine.
Hope this helps,
02-08-2016 11:01 AM
I have the following set in the station settings, shouldnt these setting pass to the deployment? I have base deplyment licenses, how do I check the deplyment settings?
02-08-2016 11:06 AM
These will only pass to the deployment machine if you explicitly include them in your deployment and have them install to the cfg folder on the deployment machine.
Here is a whitepaper on it: http://digital.ni.com/public.nsf/allkb/E5E4FEADEFE6023D862571590000C5CC
Otherwise, if you use the Full-Featured TestStand UI on the deployment machine it will have the menus. The menu isn't there in the simple UI. You could create a little tool just for changing these. That might take a bit of work though.
Hope this helps,
02-08-2016 11:31 AM
ok thanks! these are being included in the deploment so I will have to check the files. which file is this located in stationglobals?
02-08-2016 12:46 PM
My guess is that it's stored in TestExec.ini but I haven't verified this.
