03-19-2013 01:59 PM
Thanks Doug,
Yes, it seems to be working correctly with a lock name now. I can't hold the lock around multiple steps (although I'd like to so no need to modify each step) due to different step types inside the sequence file. The other step types call other unrelated code modules, so I don't think a lock is required.
I wonder if I need to put a lock on the default Wait. Thus far, it's working fine without it.
ph
03-26-2013 09:39 AM
Thanks Doug.
I think it's working fine now as I put the lock name on my steps. I removed the lock from Wait steps as you mentioned before the steps that come with TestStand doesn't require locks.
ph2
