NI TestStand
Run-Time error details
Hello
I'm writing a dll in C# 2010 and i want to fill the "Details" box in the Run-Time error popup in case of an error
I fill the ErrorMessage string in Teststand but in the popup box "Run-Time Error" it says "No details available"
How can i sent the ErrorMessage string to the "Details:" box in the "Run-Time Error" popup
This is an example of my C# code
public void LABPRN_ExecuteJob(ref bool ErrorOccured, ref int ErrorCode, ref string ErrorMessage)
try
        if (_sTmpFileHandle != null)
                    _sTmpFileHandle.Close();
                    _sTmpFileHandle.Dispose();
        //Rename file from .tmp to .job
               File.Move(sTmpPathName, _sJobPathName);
                _sTmpPathName = System.String.Empty;
                _sJobPathName = System.String.Empty;
      catch (Exception ex)
                ErrorOccured =true;
                ErrorCode = -1;
                ErrorMessage = ex.Message;
thanks in advance
Tonnie
(3,728 Views)
Tonnie,
how do you call this method? To be precise: How do you pass data by TestStand?
And:
Are you sure that "ex.Message" is NOT an empty string?
Norbert
Norbert
Expert: Geometry
(3,692 Views)
Hello Norbert
I have attached the step setting to this message.
ex.Message is not an empty string. I have attached a screenshot where you can see the string
Tonnie
(3,689 Views)
Tonnie,
you are passing the wrong parameter for ErrorMessage. You have to pass "Step.Result.Error.Msg".
Norbert
Norbert
Expert: Geometry
(3,683 Views)
