NI TestStand
Results.TS.StartTime
TestStand stores the time at which each step is started in Step.Results.TS.StartTime (which is then copied to Local.ResultList). However this is given as the time in seconds since the TS engine initialized. How can I convert this into a time string?
jackson
(3,105 Views)
I cannot find the variable you're refering to.
The time in seconds that's logged to the Locals.ResultList is as you say from when the TS Engine was initialised, so the easiest way I can think of to get the actual start time is to make a call similar to :
Time(false, 0,0,0,0,Locals.ResultList[0].TS.StartTime, true)
The last parameter to the call of true sets it relevant to the time the engine was initialised.
Hope that helps
S.
// it takes almost no time to rate an answer Smiley Wink
(3,105 Views)
Hello ,
 I use this to time stamp every step results. What Odd is they appear to be 10 seconds sooner than the window local time which given by the time(), Date() function.  What is wrong with the teststand timer
Tphan
(2,621 Views)
