08-11-2014 10:59 AM
Only if i ENABLE any result type only then the SequenceFilePostResultListEntry is called
the thing is I have aditional results & I save them in TDM format
hence I dont need the options from the Result processing
is this functional behaviour expected from teststand
10-07-2014 09:07 AM
Hello aparab,
can you please explain it a little bit for me,
or modify the attached TS 2013 Sequence to show what you mean?
Thanks a lot
10-07-2014 10:24 AM
Hallo Alexander,
I want to convey that only when the option in Result Processing is enabled then only I get the Sequencefile post resultlistentry callback activated.
10-07-2014 02:26 PM - edited 10-07-2014 02:27 PM
Hello aparab,
i have greated a StationGlobals ReportActivated and fill this global in the callback
ReportOptions with the the flag, if the report generation is disabled or not.
In the SequenceFilePostResultListEntry a if structure is insert that ckecks the flag.
Hope this helps.
