NI TestStand
Reporting mechanism on HTML report file, using TestStand 2012 SP1
I am using TestStand 2012 SP1, where the reporting mechanism is configured to be in HTML format.
I am not getting the full report of the sequence file which is executed, however I get a part of it printed on the HTML file.
The following are the configured "Report options",
Contents Tab:
Report Format : HTML Document
Default Numeric Format : %$.13f
Include Step Result: Checked
              Result Filtering Expression : Result.Status=="Failed"
              Include Test Limits : Checked
              Include Measurements : Checked
              Include Arrays : Insert Table
              Filter : Include All
Include Execution Times : Checked
On-The-Fly Rporting and Only Display Latest Results : Checked
Select a Report Generator for producing the Report Body : DLL
Report File Pathname Tab:
Generate Report File Path : Checked
       File Name/Directory Options : Specify Report File Path by Expression
       Report File Path (Sequential Model) :
                        StationGlobals.TopLevelReportPath
                        +RunState.ProcessModelClient.AsPropertyObjectFile.DisplayName+"Report_[<FileDate>]<Unique>.<FileExtension>"
Please let me know a solution to this problem.
Dharani
(4,333 Views)
Hi Dharani,
Your current result filtering options are set so that it will only show failed steps. Is this what you wish to show? What parts of the HTML report are not being shown?
Jason
(4,120 Views)
Jason,
Thankyou for replying.
Yes, I need only the steps which had failed to print on the report file.
The problem what I am facing is, if there are 10 failed steps, the report is not printed for all.
Also the order of printing is not correct for the first step and the last step which is printed on the report file.
I had used "Post Expression" for printing data for all the failed steps. Normally these post expressions should be printed beneath the step in the report file.
However,
1) For the first step which is printed on the html file, the post expression gets printed just above the step and also it gets printed beneath the step.
2) For the last step which is printed on the html file, the post expression is not printed beneath the step.
Please let me know if i need to provide some more information.
Dharani
(4,099 Views)
Dharani,
If you could post a simplified version of your sequence file, I can check it out for you.
-Jason
(4,081 Views)
