It seems I am unable to enable the following item under the Report Options menu item.
Result Filtering Expression is disabled and always set to All.
Even with the tutorial example, Computer.seq, as described in Chapter
10 of the pdf Using Test Stand, I am unable to modify the control to
select Exclude/Passed/Done/Skipped. Same problem with a brand new
sequence file.
Am I missing something??
