10-11-2012 05:56 PM
TestStand 2010 SP1 + LabVIEW 2011 + Report Generation Tookit
After installing a deployment, the location of NI_Excel.lvclass is expected to be at ...\VIs for <project name>\SupportVIs\Excel\NI_Excel.lvclass (see attachment)
but the path of the file is located at ...\VIs for <project name>\SupportVIs\data\NI_Excel.lvclass
In the deployment image, under the target folder, the file is in ...\VIs for <project name>\SupportVIs\data\NI_Excel.lvclass
and the lvproj finds the file.
The lvproj in the installation finds the file in ...\VIs for <project name>\SupportVIs\data\NI_Excel.lvclass
Renaming the folder from data to Excel fixes this problem.
Has anyone else run into this problem?
10-17-2012 06:20 PM
Are you deploying the VIs using the deployment utility or are you installing the toolkit seperately?
07-18-2013 07:59 AM
I am facing the same issue when I create the TS deployment through utility using TS2012.I thought of adding the file to the Teststand workspace and give the destination in to supportVIs directory.But even tthat didn't worked as it was copying all excel vis in to two locations.
Even adding the Directory path in to TS search directory options to "\data folder" is not resolving the issue and LAbVIEW Vis are not able to locate it.
