09-02-2015 06:59 PM
All,
My teststand has been giving me issues recently and now I can not find my report configuration option under Configure in the menu now. Does anyone konw how to add it back in?
-Andrew
09-03-2015 10:53 AM
That comes from the configuration entry point in the process model. My guess is that your machine can't find the process model. Generally a search directories issue. Sometimes the model is moved or deployed to the wrong location though. Last option is that it could have been deleted out of the proces model.
Is this in the Sequence Editor or User Interface? You should be able to look at the status bar at the botton to see what process model is loaded.
Hope this helps,
10-26-2020 06:04 AM
Thank you. That was helpful.
A project required a different configuration directory and somehow when I reset the configuration directory, the model was not automatically reset.
I had "Model: none" in the status bar. I fixed it by going to "Configure > Stations Options > Model" and made sure that "Use Station Model" was checked.
